Danfoss thermostat hysteresis
Esben Henriksen shared this question 8 years ago
Hi Zipato
I have 7 Danfoss thermostat installed which my Zipatile is controlling. It seems to work fine in the 2 weeks I had it installed.
I have a question. In two of my valves setup, I can controll the hysteresis, but I can't with the 5 others. I don't know if it is important, but it seems to be a way to controll how narrow room temperature can be controlled.
Could you tell me why the "H" is only possible to access for 2 off my valves? See attached.
PS. I have earlier got very helpfull assistant regarding thermostat from Ivica Čevis :-)
BR
Esben
Hello Esben,
The Hysteresis control is available only for Virtual Thermostat PRO applications, and judging from the state of your thermostats, not all of them are thermostat PROs.
You can read more about PRO/SMART features on the link below:
https://www.zipato.com/how-it-works/features
Please note, Zipatile users get a single virtual thermostat PRO available to them and it comes predefined to use Relay1 and Relay2 as the thermostat outputs and the Inbuilt Zipatile temperature sensor as the thermometer input. This Thermostat is fully customizable, and serves as an example.
Brgs,
Vedran
Thanks Vedran for you answer.
Esben
