Does Zipabox work with Nexa LEST-701 repeater?
Michael Ericsson shared this question 9 years ago
Having trouble reaching every corner of the house with only the box, so I was thinking about buying a Nexa LEST-701 signal repeater. Will it work? Can't find it in the list of Nexa products when adding a device.
Oldest
  • Oldest
  • Newest
It has not been tested yet, but if that repeater only repeats the transmitter message (or the message from the box) and does not change it in any way, I think there should not be a problem.
Thanks for the reply!
Any idea what I should try to connect it as?
If it works the way I imagined it should, you wouldn't have to join it with the box or you would join it as the device you are trying to control. For example, if you are trying to control the plug-in, you put the plug-in and repeater in learn mode and near the box and start join procedure like you are including the plug-in only. But this is just a speculation...
Did it work?
