Fade-out rule of dimmer (Qubino Flush 2) not working
I'm trying to figure out how I can slowly decrease a dimmer after the lamp has been on for 10 minutes, but it looks like my Repeat isn't being triggered.
The rule I have so far:
The send-message blocks are for debugging only, but somehow they are never triggered.
What am I missing here?
Try When qubino intensity != 0
etc
etc
Thanks, that didn't make a difference though.
I've edited the rule to test the repeat function:
...but the send-message still isn't triggered.
[edit]
Searching this forum and the internet shows that many people are having issues with the repeat puzzle.
[edit]
Yes - i have a similar Dimmer rule in use with the repeat puzzle.
It only worked once a few weeks ago. Never before - never after - nothing changed since creating the rule ....
Fad in and out should be puzzle piece wher you can set time and how often a dim command will sent. ea. 0% to 100% in 100 seconds. If you set it to send 100 commands it will send 1 command a second, and if you set 50 commands it will send 1 command every other second. But of coursers you would block the sending of other commands during this time.
My wish is that this would be built in to the dimmer unit itself. You can change some dimming time parameters on both Qubino and Fibao, button is only when you press on the button I think.
5. Automatic control - dimming step size
This parameter defines the percentage value of dimming step during
the automatic control.
Available settings: 1-99 - dimming step percentage value
Default setting: 1 Parameter size: 1 [byte]
6. Automatic control - time of a dimming step
This parameter defines the time of single dimming step set in parameter
5 during the automatic control.
Available settings: 0-255 (0-2.55s, in 10ms steps)
Default setting: 1 (10ms) Parameter size: 2 [bytes]
7. Manual control - dimming step size
the manual control.
8. Manual control - time of a dimming step
7 during the manual control.
Default setting: 5 (50ms) Parameter size: 2 [bytes]
Have any one tried this?
http://www.fibaro.com/manuals/en/FGD-212/FGD-212-EN-T-v1.0.pdf
the manual control.
