Fibaro motion sensor does not save konfiguration
Erling.johansson shared this problem 6 years ago
Fibaro motion sensor does not save konfiguration, for example if i change Led Signalling Mode till Led_Inactive and takes save, the answer is Device Saved but if i get back to konfiguration again it is not saved.
Has a Zipabox
to change configuration parameters, please click on the title of configuration parameter and part with Send/Retrieve/Cancel buttons will show up. Use Send button to update parameter's value and Retrieve button to check it. Note: device should be woke up to receive updated value.
