How to add Esic WT450H?
Petter Grönskog shared this problem 9 years ago
Hi.
I have a Zipabox Duo and trying to add Esic 450H with no luck. :(
Read all articles on the forum and tried several of the solutions that seems to work for others.
6pcs WT450H have been connected to a Tellstick Net for a couple of years with no problem.
Shutdown the Tellstick and all WT450H before trying to join the Zipabox.
BR
Petter Grönskog
Replies (6)
I have tryed to add Esic 450H too for a long time now without success, sadly.
I was trying to join a Oregon humidity/temp sensor yesterday, and struggled for over an hour. I think there might be a bug in the (433) join functionality.
Btw, I have added two of those Esics earlier, and I cant recall having any problems.
Hi Marios.
Do you have Zipabox duo?
Nr
Petter
Yes, I have the Duo
I just bought a new Esic 450H and it was not any problem to add it on my box but still my old one is not possible, so it feels like old ones can't be connected to Zipato...
Ah, great! I'll try with a new one!
Thank you for the information. :)
/P
Just be aware that the Esic might not be ok to use with rules and thermostats. I have two Esics included and both are spiking several times per day. Suddenly I get readings that says for example 120 degrees
I have sucessfully added a Esic 450H. When I link it in a virtual thermostat pro it used humity as temperature.
How can I fix this and make it select temperature?
Hi guys, do you still have ESIC connected to your Zipabox?
