HTTP devices not working
Michel van Osenbruggen shared this problem 9 years ago
Hi, I have a big problem. I use a lot of virtual switches that send HTTP commands. Since the upgrade to the latest version NONE of them work anymore! I checked the config and everything still works. How can I fix this? Nothing is working in my house now!
Replies (12)
Michel,
Mine still work. With the upgrade to beta 1.2.15 i had to change the method from get to post to get them to work again.
Groet,
Roland
Well in my case that is not so simple, so it confirms that HTTP get is broken after upgrade.
I have same problem as you Michel. GET doesn't work but POST does.
OK thanks for confirming. I hope Zipato can fix this quickly. A lot of stuff not working here :(
Same here... I submitted a ticket a week ago.
Hmmm that is not hopeful :( I'm sure we are not the only customers having this problem. Seems like something you need to fix very quickly.
I just heard Zipato is aware of the problem and they are preparing a patch. Should be fixed this week.
Great news! It's a shame they can't communicate better.
I had to downgrade to the previus old version in order to keep all working well... until they fix it. (it is a temporal solution)
i think i have the same Problem.
after the last Update the pushover Service does not work.
I tried everything, set up the rule again, set Mail to put or get...nothing.
It still stopped working
Chris
Guys,
The GET method works again in 1.2.21 firmware which we've released yesterday.
Anyone still having issues with it, upgrade the controller, sync the rules and it should be fine.
If its not - you know where to reach us ;)
Cheers,
V
I can confirm that it is now working for me. Thanks Vedran!
Do you have a feed where you announce firmware updates and what has changed?
This was only a hotfix for two minor issues as the firmware in general looks solid, and has received many positive feedbacks from the customers in the past couple of days.
With every official firmware release there is a changelog available in the "Messages" panel on the web UI.
V
Well... for me it wasn't minor at all. Several of my rules have not been working because of this for roughly two weeks. I for one do not visit the dashboard all that often. I would like to see a feed or blog that I can subscribe to so I know that there is an update available. If you look at Ubiquiti (https://community.ubnt.com/t5/UniFi-Updates-Blog/bg-p/Blog_UniFi), they have a blog for this kind of thing.
Hi guys,
I was using pushover notifications for several months with no issues at all but after upgrading to latest firmware (1.2.21) the Post Method stop working. My notifications are silent now. :-(
I have changed all my http requests from get to post.
Must I change them again, when I upgrade to 1.2.21?
I have the same Problem with Pushover.
No Notification
Since last upgrade it is working again ....
Not working for me.
It works for me again. Thanks.
4
Tested 1.2.2x again today. Notifications using Pushover.net API does not work.
Rollback to 1.1.38 fixes the problem.
Latest firmware still breaks HTTP devices.
Prowl doesn't work either after upgrade.
After upgrading to 1.2.24 (latest firmware available) Pushover.net push notifications work again as expected.
