I want to make a level system.
Good Morning!!
I want to make a level system in a water box, using Four Icos Mini Buoys and two switch zipato with two inputs and two outputs is it possible to use in my rule some virtual device shows the percentage status of the box, @apoio zipato would help me get started or any tips.
Hello Willias,
I actually want to do something similar for may water tank, since I haven't found any dedicated sensors for water level via z-wave/zigbee I decided to make my own with an arduino but haven't started (no time). However I know there is a virtual level control but cannot be directly attached to any sensor of control so probably would be better to use a virtual meter instead and just populate the meter with the percentage using rules.
I dont have experience with the Icos Mini Buoys and actually couldn't find any useful link to them so I cannot help you with that... I assume these mini bouys interfase by wifi or something like that, if you can program HTTP requests on their controller I'm sure you can integrate them into zipato.
Hello Willias,
Muito obrigado @Alberto Macias
