include sonos beam
JORGEN ARTHURSSON shared this question 6 years ago
how do i put sonos beam in inclusion mode ?
Press the connection button next to the LAN Port.
Thanks for answer. Should i press only one time ? i tried yesterday, but it did not include ?
Yes, only one time. I have also a Beam.
I Can’t get it Work. I press button but no reaction when i have zipabox in inclusion mode. Do you have any suggestion?
Whats happend? Are your sure that there is nothing under devices/IP?
nothing is happening. After about 20 seconds, discovery fininsh. in the meantime I have pressed the button
I opened a ticket and will inform you when I have Feedback from zipato.
i have also opened a ticket about this
Mmmmh OK. Today I bought a new Sonos One and I had the same issue.
have you been able to add you new Sonos One ?
I still haven't been able to add my Beam.
Hi Jorgen, Zipato could help me. The Problem was .that I bought a Sonos One Gen2 (S18) and Zipato only supports Sonos One Gen1 (S13) yet, but Zipato add this new Generation very fast and it works now.
Can you make Screenshots or a Video from your including Process?
Hello
I have tried to include in several ways.
set Sonos Beam in discovery mode, then start zipato sonos inclusion, but zipato does not find anything.
set zipato in inclusion mode, then set sonos in discovery mode, but zipato does not find anything.
i have checked that zipabox and Sonos are in same network.
But still no success to include Sonos.
can you explain how you did when you included your sonos Beam ?
Hi Jorgen
You've already described the right path. Please try to restart the zipabox and the Beam and then try it again.
i have done that to. but still no inclusion
