iPhone App problems
Avelino Junior shared this problem 12 years ago
The iPhone app has som bugs, when you connect local it wont show the endpoint name that you defined for 433mhz modules also when you try to use the Zxt-120 controler it will crash the app or it will simply not wok and will not send the commands to zxt-120...and can't be used.
Can you fix that?
Thank's.
