KNX Devices
Thibaut shared this problem 12 years ago
Hello
I write to you to have your help with the expansion module KNX Zipabox.
I have equipment Hager KNX control and I want this installation with Zipabox. My setup consists of:
- 1 TX314 (230V inputs Module 4)
- 1 TXA206A (4A lighting module 6 outputs)
I added the "KNX BAOS 820/870 Serial" device in my programming with the ETS. I followed the steps to import my project in Zipabox and it works.
Since the control interface, I can turn on and off my lamp by clicking on the symbol, by cons, when I turn off my lamp using my switch, I do not have the state back on the Dashboard of Zipabox . Is this normal?
Thank you in advance for your response.
cordially
