LED Lights (side) Zipatile flashing
The LED Lights on the side of the Zipatile Device are turning to flashing red from steady white when a movement is recocnized.
All Alarms are set to "Inaktive" or has been deleted.
Why the movement is tracked and turned to the command "flashing red LEDS"?
Perhaps somehow one alarm is reporting. Blinking red is alarm breach (if I remember correctly).
Yes... but the key question is why "somehow"?!
It's simple. You should check the sensor and replace the indicator.
I did that a couple of months ago when I found that the led was active but triggered red. In this case, efficiency and quality are important. It would help if you found a good and proven set of led bulbs to do this. I found such a set on Amazon, and you can see it here: https://www.amazon.com/car-lights-car-led-lights/dp/B09L86JRRM. If you read the description, you will understand that this is a completely new generation of such bulbs. For me personally, it is very efficient and useful to have such a set so you can check it on your own experience.
