no blue channel for RGBW bulb 2
Luuk Engelen shared this problem 9 years ago
Hi everyone, I have a problem using the Zipato RGBW bulb 2 and z-way. I can include it (it is known as the version 1 of the Zipato bulb), but when I check the settings in the expert gui , I only see channels for soft-white, bright-white, red and green, but not for blue! I can change the values for the existing colors and they work fine. I have heard that this is solved with a firmware update, but i cannot find a firmware file for the bulb2. Can anyone help me please?
Hello Luuk,
I have also a Zipato RGB bulb2 and in my case it works great. For changing colors and intensity via web UI, you can play with the red-marked dots (RGB/White) and blue-marked ones (intesity).
7f5ba9cf8be29bae8b8cf6703ffce1ed
Hi Pablo,
Thanks for the comment, but i am not using the Zipato box, but a Raspberry with a Razberry z-wave controller with Z-Way ui.
br,
Luuk
Hello. I Also use Z-Way and have the same problem. Even after exclusion and re-inclusion the blue channel does not show up. Is there anything new or any Information from the Vendor?
fix is available for that issue. Did you open ticket at support? If not, please do it, so we could resolve it shortly.
How have you fixed it? Please help
