"No Endpoints" when adding 433MHz wall plugs
I added a couple of 433MHz wall plugs and they were discovered by the Zipabox.
After a couple of days I wanted to add a couple of more but instead of displaying switch details, it shows "No Endpoints" in the device manager.
I tried re-adding them a few times, even using latest beta firmware and previous firmware without any success.
In order to try to determine the problem I decided to remove the working wall plugs too and re-add it again.
Unfortunately these device now also no longer shows details but also "No Endpoints".
Any ideas how to fix this 'No Endpoints' issue?
I am a developer at zipato and if you send me your user name (zcerovski@3plus.hr), I will put the latest FW on your box that should resolve your problem
Halkan, simply raise a ticket on support.zipato.com
Naarz is right, but do as you wish.
I just wanted to speed things up, but I understand you, it is good to be cautius
Just had the same issue with Somfy RTS motors. Last week it was fine and they added. This week they show as no endpoints. I updated to the latest Beta firmware and still does not work. Embarrassing as I was installing at a Somfy distributors showroom.
same issue
i used to have timer setting in the comfy roller shutter since some days i have no endpoint message and no way to fix it! firmware looks update 0.9.999.8e
please help soon
thanks
same issue
please help soon
thanks
hey everyone contact Zeljko for this fix. An update is on its way to the beta firmware, but for now when adding use the old control panel UI then return to the new UI to update the configurations.
Can you please help me too, to update the firmware? I'm stuck with my tablet (Ticket CEC-889-27189). The sensors I would like to attach (eg. Fibaro smoke sensor 2 FSG-002) are obviously so new, that nothing can be coupled with the old firmware. Or the tablet is defective...
I also want help. Seems I can't add any new devices :(
Send box SN on
Send box SN on
I
am having the same trouble with the box I have just bought, i can add lightwave
products but there are no endpoints? the Z-wave items I've added work fine. Now
it wont let me remove the none working lightwave products. I get the message
"service not available" i also get the same message when i try to add
my nest smoke alarms. Since i bought this box to interface between the
different technologies i have this is pretty disappointing so far.
I
Try to restart the box and then upgrade to the latest beta release.
Then delete the device, sync and re-include it.
It works for me :-)
It works for me :-)
I tried the latest official and beta firmware, neither worked with my lightwaverf products
Douple post...
Douple post...
0.9.999.8p beta firmware works for me with Nexa and Proove 433MHz devices.
Kimmo
Kimmo
Just tried updating to beta again, rebooting, still will not let me delete the 433 lightwave kit. it says " service is currently unavailable, Please try again later"
Still that same message for adding Nest products too
I've now tired restoring factory defaults and that doesn't work either! says "failed to restore factory defaults!"
You are experiencing problems with server connection I guess. You should contact support@zipato.com for further assistance.
