on off switch Fiabro
Zipato guru shared this problem 10 years ago
Hi;
I have a fiabro switch installed with a zipabox working fine but suddenty it started showing the false value on the zipato app .I mean if the light is turned off the app and the interface shows that lights it's on and if it is on sometimes that is is offline. It seems that this relay do not show its real state.
As well i have a fibaro rollershutter the posiotion is set at 22% once i wantedto rise it uo ton100% from the app it doesn't excute the action? and show in the app 22% then 100% then fastly return to 22% .so i had to rise it down to 0% and then to 100% and it worked.Why doen'ts the roller shutter move directly from 22% to 100% without rise it down and then up?
thank you for suport
I have the same problem wit my qubino relays.
I many cases after 5 to 10 seconds the state change to the right value. But in the most of cases the value doesn't change.
did you submit this issue to zipato support and what did they say to you?
no, I have to many other issues and this isn't the biggest problem.
Another fact: It isn't reproducible....
