Partition number and zone Numbe
A.Alsahlawi shared this question 10 years ago
I need to know benefit of Partition number and zone Number?
Ok. so if you have a small house (or flat) and you will use the house evenly, you will only set up one partition and all sensors will be separate zones (zone = sensor). To have separate partitions makes sense once you need to separate different areas of a building with different alarm rules...
Well. This is a mistery for me either.
I want to know it also :)
Thanks for the explanation .. and if possible explain more in detail by the example
Try this one with a Translater: http://zipabox.de/die-zipabox-als-alarmanlage/
