Philips Hue and Osram Lightify
Claas Voigt shared this problem 10 years ago
I try to control my Osram Lightify with my Zigbee Module and some Phlips Hue (Bridge 2.0).
In FW 8a I can not include the Bridge and in 8q I can control the Hue, but not the Lightify.
Has some one any solution?
Best
Claas
You should be able to control osram on .8q. It is possible that it stopped working after upgrade, but if you delete it, sync and re-add it, then it should work.
Before re-add the bulb, reset the bulb.
Or you add the Osram lightify to the Hue Bridge.
I had to resync lightify after upate to 8q. Since then everythings works fine!
what means resync Lightify? I control my Lightify Witz a Zigbee Module.
Claas
Done. Works - THX
Claas
