Problem with zipato motor control (Pan08) and somfy blinds
Hi all,
In some project that we connect pan08 to short length somfy blinds , it won't work properly.
When we send command to pan08 in such cases; we hear a really click on and immediately off.
Only with short lenght somfy blinds we have this problems.
I guess the current (amp) that blind works with , is very low, near zero maybe and module think its limit switch active.
Or maybe another reason that you have had the experience.
Amin,
It is possible. It uses electricity measuring in order to identify the load.
Have you calibrated the motor controller? Via tripple click?
Hi Attila,
Yes we calibrate it , via 4 seconds press of inclusion button not via triple click,
Is there any solution you think?
Hi Attila,
Well, I suggest you try Fibaro or Qubino shutter. There is nothing else you can do with Zipato.
