Push value to variable via http
Is it possible to push a value (time) via http to a variable?
Thanks.
DUC750
No ideas?
No ideas?
yes, use API
yes, use API
But how? I can't find any commands for use with variables.
Using php to set a virtual device
$url = "https://my.zipato.com:443/zipato-web/remoting/attribute/set?serial=xxxxxxxxxxxxxxxxxxx&ep=9d123456-b4c8-415b-a9bc-d04b0bc78452&apiKey=xxxxxxxxxxxxxxxxxxxxxx&value1=" . $infos->current_state->temperature . "&value2=" . $infos->target->temperature[0] . "&value3=" . $away;
$res = file_get_contents($url);
ep is the endpoint UID of my virtual device if I can remember
Hello Jean-Louis,
thanks a lot, I've tested it with virtuel devices, but i haven't found a possibilitie to handle the format 'time'. But I will test it again if I'm at home.
Best regards
DUC750
Hello Jean-Louis,
Best regards
DUC750
