Rearrange issue with Zipatile new UI
After I install last update I found finally good news about Zipatile home screen !
I test all features and I found and issue.
It's related with the rearrange function not in the home screen (with new colored icons). It's related with the widgets included inside.
When I select 'rearrange' in on widget it's grayed but just after few milliseconds it back again to normal condition and I don't have time to move it. Just one time being too fast I could move one position...
By the way... One question....
Why rooms, types and other basic icons are not included in the customize icon list?
When for example I want to change the color (only the color) of the Rooms icon and I enter in the customize screen, after change the color the icon is changed to the first one in the icon table.
As I tip... If I select 'customize' default, the icon is restored and not the color. I think it's another bug but at least it can be used to finally set the desired combination.
Please add all icons available in the zipato website !!!!!!
Thanks.
Pedro.-
Second the 'color change ' issue. Workaround is to change to desired color then restore the icon to standard et voila color and icon changed.
Rearrange issue already solved.
Thanks.... but... now the workaround we found to customize color and not loose the default icon seems not working... :-/
Zipato style... :-)
Zipato style... :-)
