rule and Camera
Hallo, is it possible to command external IP camera using rules? if yes which camera has the best Zipato (Zipatile) compatibility?
thank you for answer
Enzo,
I got this list from a third party integrator, which has been integrating with zipato for a long time. I haven't got to that point with my Home integration but there are a few experimented users that can give you a better guidance.
IP cameras
IP Camera AXIS M3114
IP Camera Brickcom-50xA
IP Camera D-Link DCS-5020L
IP Camera D-Link DCS-930L
IP Camera D-Link DCS-932L
IP Camera D-Link DCS-932LB1
IP CameraEDIMAX IC-7001W
IP CameraFoscam C1
IP CameraFoscam FC1403P
IP CameraFoscam FC2401P
IP CameraFoscam FC2403P
IP CameraFoscam FI9804W
IP Camera Foscam FI9821W V2
IP Camera Foscam FI9826W
IP Camera Foscam HD816P V2
IP Camera Foscam IPV38P2P
IP Camera HIKVISION DS-2CD2232-I5
IP Camera HikVision NC303-XB
IP Camera NEO Coolcam NIP-32
IP Camera PTZ P0132
IP Camera StarVedia Vanilla IC717HD
IP Camera Thomson DSC-323W
IP Camera Thomson DSC-523W
IP Camera Thomson DSC-723W
IP Camera Thomson DSC-923W
IP Camera Triclouds C1100-W
IP CameraTriclouds C3033-W
VIVOTEKFD8136 IP Camera
VIVOTEKFD8169 IP Camera
IP CameraVIVOTEK FD8362E
IP CameraVIVOTEK FE8171
IP CameraVIVOTEK IB8369
VIVOTEKIP7161 IP Camera
VIVOTEKIP8132 IP Camera
VIVOTEKIP8133 IP Camera
IP CameraVIVOTEK IP8133W
IP CameraVIVOTEK MD7560
IP CameraVIVOTEK MD8562
IP CameraVIVOTEK PZ81X1
IP CameraWansview (NCM627W, NCM629W, NCM625W PTZ NCM621W, NCM630W PTZ PTZ NCM626W,NCM628W)
IP Camera WGP-100-CB
Zipato IP Camera NCM629GA
Enzo,
IP cameras
IP CameraFoscam C1
IP Camera PTZ P0132
WOW!! a lot of cameras!!
thank you, and each of them could be commanded by Zipato rules?
Enzo,
As I mentioned, I haven't integrated cameras in my system yet, but I assume all these cameras will have the same functionality as Zipato cameras, not sure to which extent each of them will be integrated with Zipato. I would recommend you open a ticket on Zipato Support asking about compatible cameras and if you have one in mind provide brand and model and they will be able to assist. What I know is that any IP camera with ONVIF protocol can be integrated to some degree on Zipato.
Enzo,
