Rules Stopped Working
Nathan shared this problem 9 years ago
Everything was working fine for a few weeks and then all of a sudden two of my wired switches dropped offline. I deleted one of the switches and then re-added it to the network. I recreated my rule that turns on lights outside my house at sunset and then turns them off at 2am. Unfortunatly, they just stopped working.
Oldest
  • Oldest
  • Newest
Replies (7)
Did you remove the old one from the rule? If old (delete) devices still are used in rules then the sync won't work.
I did. I even re-created the "turn off the lights at 2am" rule from scratch after deleting the original thinking that might work. Unfortunately everything was still on when I woke up.
I noticed that sometimes when there was a power failier some of my device are off-line. "Network Heal" allways helped.
Unfortunately I tried that too, with no luck.
Now none of my rules are working. The motion sensor is sending motion and the switch is online, but it's not sending a notification nor is it turning on the light.
This thing isn't very reliable is it?
Did you install any IP devices such as a Nest thermostat or Sonos speakers?
Apparently such devices are causing the box to run out of memory, due to a bug that's being looked into.
