Scenes makes Zipatile slow and unresponsive
Thomas shared this problem 8 years ago
I have scenes with 7-10 devices (mostly Fibaro dimmers) and for some reason only 50-70% of them reacts to the scene. And 5-10 min. after running the scene the Zipatile has massive delays in all rules.
If I run two scenes to fast (within 5 min.) it almost needs a restart before things run stable again.
Is it just my setup or does scenes seem to be slowing down Zipatile?
I believe this is isolated to you. I had no such issues with my old 1st gen zipatile.
Issues like these are most likely caused by bad mesh network between the Z-wave devices in your installation, or almost all cases reported to the ticketing - cause was failed nodes still on the controller.
Remove all failed nodes, and run the ZWNTUT on the Zipatile. When running the ZWNTUT keep the "skip sleeping" and "disable retries" checkboxes ticked.
I have the same problem. When I run a scen, some of the avtivities are skipped. Often the rgb controllers from fibraro fails. The work fine when running them from the device search, but when scenes are run about 75% of the scene is run, regardless of wich scene i run.
