scheduler doesent work in new rules
patrik wihlborg shared this problem 8 years ago
Freezing cold here, Need input!When i make new rule with scheduler it doesent work. (used to work before)
New rules without scheduler works.
I have old schedulers and they work.
I tryed meny times and never copyed rules, still same problem.
I submited a ticket but zipato "dont have time to look in to it" and sugests payed service but cant
even give info on paid services. Im realy close to bin this box and go for something else.
Meantime, what would be the best solution to get external scheduler in to zipabox?
Im thinking HTTP comand from ftttp google calender, could it work, eny better ideas?
Hi. Not sure what might be wrong. Surely you can do workaround by ifttt as scheduler which sends a webhooks to a virtual sensor (as on) or meter ( a value). Then once the rule is run, you need to reset the sensor (to off) or the meter (to a different value) so it will run the next time the scheduler fires.
