security module
how does this security module work? It has several ports, Z1, Z2, Z3, COM, Z4, Z5, Z6, COM. as there is no manual, I am assuming that when using a NC door sensor, the wires go to Z1 and COM to form a closed loop?
Likewise, if adding a second zone I use Z2 and same COM?
I have put all the zones in NC configuration.
So why do I keep getting the error that the zone is not ready?
I even put that the alarm can be armed with the zone in any state..........changing it to inactive or active gives same error.
What more do I need to do to get it to work? Only when I by-pass the zone will the alarm be ready to arm......so it has something to do with the zone, but what?
Getting desperate, thanks for any help.
Hello Darkwing,
Try to change status on the sensor after you create a new zone, synchronize and refresh browser tab afterwards.
If that fails try to BYPASS zone, activate alarm, deactivate alarm, remove BYPASS, activate alarm and deactivate alarm again.
Manual for security module can be downloaded from Zipato knowledge base:
http://support.zipato.com/index.php?/Knowledgebase/Article/View/68/89/security-module-user-manual
Hello Darkwing,
What is the risistor valua whe can use?
5.6 Kohm
5.6 Kohm
Thanks,
cant find it in the manual.....
Thanks,
The manual is minimalistic at best and leaves lots to wish for for entry level enthusiasts.
I would like to set a zone to NO instead of NC, but the option is missing. How can this be set?
Also, I'd like to read out a door bell button. Can this be done by the IN+/IN-?
