Server down
Johan Karlson shared this idea 11 years ago
Is it just me or are you having problems with your servers? I can't connect via the iPhone app (both new beta and old version), tried both local and remote, can't connect to my.zipato.com (page unaccessable) etc.
Any idea when you will be back up?
Replies (8)
I have the same problem
thank you
ivan
I am a new user. I wonder how often this event occurs?how many in one month?
It is possible that after a while it improved?
thank you
Thanks!/J
Is server down again at the moment?
Seems like it. Cannot do anything from the webapp or iOS app.
All devices are gone in web ui and ios apps. I can login in the apps but there are timeouts and crahes. What is a local connection good for, if you cannot use it when the server is out. Or did you loose all data and sync back to the boxes?!
Server are back agin!
Hi there - I'm showing as off-line again ... is there still a problem, or is it at my end?
No problems any more. This issue was fixed last night already.
