Setpoint on eCozy thermostat are not like defined...
0649a50f62 shared this question 9 years ago
is anybody having experience with the eCozy Zigbee thermostats?
I installed one last week and the box recognized it well. The room temperature is transmitted correct and regular into the zipabox, but if I check the setpoint (according to heating plan in zipabox virtual thermostat) on the eCozy display I can only read the last value which I have set there manually at first installation.
Thats confusing and dont let me trust in the connection between zipabox and eCozy. Worst of all, If my son is freezing due to my home automation experiments, my wife will make me freezing also :-)
Marcus
First of all I would strongly recommend you to upgrade to the latest beta firmware release. I believe it is 1.2.xx.
After that, I would also recommend you (just in case) to delete and reinclude your eCozy.
When that is done, check if your eCozy is included both as heating input and heating output in Virtual Thermostat settings, as well as in temperature input. Save virtual thermostat and synchronize.
When you do all that, try to change setpoints both using virtual thermostat (check if temperature setpoint is changed on eCozy after that) and manualy on eCozy (if the value in the virtual thermostat is not changed after that, try refreshing your browser).
I believe it should work as expected if you do all this.
Very fast answer in general and especially on Sunday. Your are great! I will check asap with ecozy if there is a chance to update the FW without their base unit and reply then whether your suggestion worked.
Marcus
I am not sure if we understood each other. I ment on upgrading your Zipabox firmware to latest beta release that should be 1.2.something
I understood you correct and updated the fw to 1.2.10. in the meantime. As eCozy is having a bug in their first fw i have sent my thermostat in parallel to eCozy (also very kind support). Now everything is new, but not all functions are running well. I am receiving manually changed setpoint correct, the programm of the virtual thermostat is working fine and also is the measured temperature perfect. But the Zipabox is not transmitting manually changed setpoints (both: app and web gui).
Is this still a problem of the Zipabox fw?
Is the eCosy not a battery powered device which is waking up?
eCozy is battery powered and there is definitely a certain wake scheme. I am running two devices. I dont know why or how, but since one week the setpoints transferred from Zipato Apps (IOS and Android) as well from the Web Intereface to the thermostats. Everything is fine know.
