Siren output voltage on Security expansion module
When I measure the voltage on the supervised siren output ( Bell+ and Bell-) I don't have +12vcc but 0Vcc.
If I push the siren button on HMI, the voltage doesn't change.
But the state of the siren button siwtch from ON to NULL.
How I can obtain the +12vcc on the supervised siren output ?
Thanks,
Further information about the other output voltage Battery and Aux :
- Battery I have more 13Vcc.
- Aux I have approximatly more than 11,5Vcc.
But between pine Bell+and -, I still have 0Vcc.
Does anyone have information on this ?
Thanks.
Thanks.
Hi dear frederic,
I'm happy to see that I'm not alone with this trouble.
Now, with your experience, I thing much more for a bug. And may be it's a hardware bug.
So, I will open a ticket may be this day to have an issue from this trouble.
But I'm very surprised that we are only 2 with this bug. May be, they often use a radio module, so without hardwire to connect a bell or siren...
Hi dear frederic,
Hi Etienne,
I am also surprised that, we are only two customers with it.
Now I am waiting for a response before to connect my siren ALTEC SI-MAX : http://www.altec-atls.fr/fr/produits/si-max.php
So actually, my alarm system with ZIPATO is unfortunately not 100% opérationnal.
I want to use a wire siren in main. Perhaps, in the near futur I will buy the Zwave Zipato Siren in second time.
But not now.
Hi Etienne,
But not now.
The siren output doesn't work that way - you will observe voltage only when you connect the load on the siren output.
Thanks for your reply.
I will test it this evening and I come back to you tomorrow morning.
Best regards
Best regards
Is it the same thing for the manage output ( pgm out )?
If I desire test it without accessories connected, with value of component must I put ?
And between witch connector ?
A- for bell output ?
B- for pgm output ?
B- for pgm output ?
Ok,
In my installation, the alimentation of the siren is provide by the AUX output of my Zipato.
So, I need to use Bell+ to connect the input of siren.
I don't use Bell - in my case.
Can I connect together the outputs AUX - and Bell - to obtain the same referential ? (0V)
Do I need to install a resistor between Bell+ and Bell - to the siren output.
On the Zipato notice, it's write that we need to use a 1Kohm.
Is it correct ?
Thanks.
Ok,
Is it correct ?
Thanks.
Another topic already exists.
I've opened another topic a few days ago.
May be it's better to close the another topic?
https://community.zipato.com/topic/security-module-output-bell-0v
Chers
Chers
