Somfy blinds/awnings stop working after a couple of times
David Pritchard shared this problem 11 years ago
I have added Somfy blinds and awnings, and configured the seconds for opening and closing. I have managed to operate them a few times. But after just a couple of times, the device stops working. After that, it seems that only deleting and re-adding the device fixes the problem.
More info: rebooting the Zipabox seems to have fixed the problem for now, without deleting and re-adding the devices.
I get the impression that issuing too many commands one after the other causes them to lock up and stop working.
Do you use a scene to control some of them in common?
At 433mhz devices it doesn't work without problems.
Build a rule in which you send one command after another, each of them with a 2-second pause in between.
No, no scenes. When I manipulate them from the device browser, and I only click once, it sometimes works OK.
But right now, none of them are working at all.
Double post. Please delete.
Yes I have noticed the same problem. Blinds will stop responding occasionally and only a soft reset will reestablish the link.
A soft reset of the Zipabox?
