SONOS:1 Not added as an audio device, just as an ip device with no endpoints
Roland K shared this problem 9 years ago
I have a SONOS PLAY:1 (want to use for sounds based on doorbell press). However adding the device (both directly on the Zipatile and via the dev center in a browser) does give issues.
- add new device
- select SONOS
- it does find the PLAY:1 and straight adds the device (whether I put the SONOS PLAY:1 in learning or not) to the system
Now comes the problem:
- you can find it under IP in the MODULE MANAGER;
- it however does not have the endpoints required (so action, volume etc)
- the device is NOT added as a audio player in the device list as it should, it has no type filled in
I also manually selected the device type audio player in the module manager, which then adds it to the device list as a sound player. However it is of no use as it does not have functions (action, volume, etc) assigned to it (missing in endpoints). And it does not appear as a module in the rules builder.
What am I missing here ? Anyone has an idea
Vedran, thanks very much. I can confirm that the issue has been resolved. I now can add it as a real audio device and the rule builders recognizes it now. Thanks for this swift and instant support. This is what support needs to be. Regards, Roland
Please open a support ticket for your issue and we will look into it.
I did already yesterday, please see #ZWA-665-17769
3
I got it now, please update the ticket with the requested information.
I sent you an email with the info. I cannot update the ticket as the ticketing system will not allow me to logon anymore. Keeps on telling me I have an invalid userid/pw even after resetting. Hope you received my e-mail and this is enough for you to continue the investigation
Can anyone perhaps post the solution here? I have the same issue and the comments are not helping much...
Zipato had to change endpoint and after
that I had to remove the device and re-join it again. That did the trick for
me. BTW I deleted and rejoined using the webapp, so not directly on the
zipatile. I do this as normal practice as I believe fixes are done in the
webapp and not perse in the the zipatile native android app, but that is
guessing from my side.
There are a number of gutter cleaning and repair services near you. You can use https://gutterscleaningcarync.com/ to find them or try looking in your local Yellow Pages or business directory.
