Sound when the post arrived
I want to get a little sound when the post has arrived. What can I buy the product that emits a signal. Can also be a melody.
guess a sensative strip can be used (outdoor proof) as trigger that the post box front door was opened. This needs to be linked with zipatile or zipato siren.
Martin,
You'll find everything you need at Clas Ohlsson and Kjells; both are all over the place in Sweden:
Kjells stocks the Sensative, Clas has the Zipabox with external 433 addon. Both stock the NEXA MLS-1105 and LML-710 doorbells which can also play meoldies...
That said, if *all* you want to achieve is to get a signal when your mailbox is opened, and you don't want any other alarm- or home automation function, you can easily solve this issue dead cheap by the use of Nexa LMST-606 magnet contact (SEK 149:-) and MLR-1105 (SEK 179:-) and connect these two so that the bell/melody fires whenever the mailbox is opened...
Brgds
Robert
Martin,
Brgds
Robert
