Rule - Start action after 5 minutes of motion
SVB Axton Residence shared this idea 6 years ago
How to make rule to start some action after 5 continuous minutes of motion.
Example 1 - in bathroom there is motion sensor. If you spend there less than 5 minutes then do nothing, but if there is motion for more than 5 minutes then start ventilation
Example 2 - garage is open and there is no movement, then close the garage
thx
Hello SVB.
This is quite easy ti setup but it is depending a bit on the setrings of your sensors.
Most presense sensors report motion and then.....after a set interval....no motion.
So if you start a timer when the first motion triggers and then set an action after 5min to start the ventilation.
And. If there is a "no motion" command between 0-5min the timer stops and never trigger the ventilation.
How?
There are several ways.
I would use a repeat block and loop it 50times with a 10sec wait block inside.
I can do a demo rule and email another day if you like?
// Henning
Hello SVB.
How?
// Henning
Hello Henning,
thanks for reply, if you post some example here that would be great.
Jan
