Support for Enocean EEP A5-20-01 (valve position) devices
David Dominguez shared this question 11 years ago
Can you add support for Enocean TRVs using the EEP A5-20-01 profile?
Devices are available from Stella: http://www.eurotronic.org/en/produkte/stella-f.html
And also this one from Micropelt (which does not need batteries!!!): http://micropelt.com/itrv.php
Hello David,
this devices were added to our wish list and we will do everything we can to support them.
Hrvoje
I added the radiator valve ubiwizz A52001 to my zipato box and I see that the valve does not regulate correctly according to the set point. Tthe regulation does not work correctly.
Example if the set point is 19 degrees and the room temperature is 23 degrees, the normally closed valve is occasionally open.
Could you find a solution, the valve is very interesting because autonomous in energy.
Thanks for your help.
