Switch someting don't turn the lamp
Michel shared this question 10 years ago
I use EnOcean Switch and module.
8 times out of 10 the rule goes fine but 2 times out of 10 nothing happened. Sometimes, I need to push on the switch 3 or 4 times
My rule is the basic one : when switch On / Lamp action On. The same for Off
Thanks, I will try the join.
I am not sure it is the switch because I have another rule where I turn off 3 lamp and sometime 1 or 2 of then do'nt turn off. So in this case, the switch is ok.
I have tried de join, buit it is the salme thing.
I tried to push strongly on the switch but it is the same.
I tried to put the box near the switch and tne micromodule. The same.
Nobody have the same problem ?
Have some similar problem but with a switch that is not fully supported yet!
