Thermostat opinions
Emmanuel Papageorgiou shared this question 8 years ago
Hello
After the lights,wall plugs,A/C now its heating time.
Do you think its ok to use the zipatile relays to control the heating or is it better to buy an external thermostat so it can be used also as stand alone?
Do you know if the MCO Heating Thermostat MH7 series is compatible with the zipatile?
Anybody owns it?
Thank you
Emmanuel,
I would give a try to Zipatile. And I am tellong you after suffering some issues and difficulties with the configurar. Bit finally it looks it works. And the all integrantes solution is great.
If not convinced, you can always buy another solution afterwards!
