Upgrade to 1.3.61?
AnkelNina shared this idea 6 years ago
Does someone upgrade to 1.3.61?
What are the changes?
It is safe to upgrade?
Replies (7)
i have same question. I think, the main upgrades, were regarding virtual weather stations. As i dont't use this feature and I don't have any bigger problems, i didn't upgrade. The only problem is, that when I login to web UI, i get this popup with notice to upgrade and have to click it away (every time)
I'm already on 1.3.98 since one month. Everything works fine.
1.3.98 is beta or official?
Beta but Zipato Betas are not really Betas. If you use V3 you have to upgrade to each beta to have all functions.
is 1.3.98 supporting zwave in cluster and/or multiservers with zwave ?
Yes, I have a Multiserver, a Zipamicro as Master and a Zipabox 2 as Slave.
Does 1.3.98 still support cluster?
Cluster is V2 under V3 it's a little bit different and is called Multiserver.
if i want to stay under V2 and start V3 on a fresh box should i still upgrade firmware under V2 to 1.3.98 ?
If I have already paid for a pro license for all my controllers to enable the cluster feature, do I have to pay again for Multiserver?
no it gets "migrated"
And you need only a Pro License for the master.
to use V3 it is mandatory to upgrade to the latest beat version and if you want to use latest features on V2, then it is recommended for V2, too.
but is zwave in cluster still working ?
1.19.93 is my latest beta .... where is 98 ?
