Virtual momentary switch
Sean C shared this question 6 years ago
Does anyone have an idea of how to make a virtual switch act like a push-button?
I have created some switches to run lighting rules through Alexa. The problem is that if I turn on VD-1 to turn on lights A,B,C and later try to turn on VD-2 to turn on lights B,C,D it doesn't work correctly as VD-1 is still on. I've found that I can add a block to turn off VD-1 as VD-2 comes on but it needs a 1sec delay before running the next part to prevent conflict. This gives a "some on... all off... some others on" situation. I'd prefer a smooth transition from "some on to some others on"
Any help/tips would be appreciated :D
