wall switch popp
            Hello . Is it possible to use the wall switch popp with zipabox? Thank you .
Hi yves,
yes, its fully supported.
regards Helle
Hi yves,
regards Helle
thanks for the reply . I n unable to make the inclusion. What software version do you use? me: 9998b
Please use the newst Beta...its running very good.
But i already used this device with an FW a year ago....
Did you pressed the button 3 times?
Hello . thanks for the reply . I have updated the box. not possible to include my switch. for inclusion, it is 3 seconds button 1? possible to reset? Thank you .
do you have the EAN Code or and ID of the device?
hello . EAN: 0696859123726
you have to push the button for a few seconds to include the device.
The you are in include Mode the red and green led will start flashing.
regards Helle
regards Helle
this is the procedure that I followed, but it does not work! can we reset the switch? Thank you
Hello . nobody uses this device?
