Z Wave routes
Pat@ shared this idea 10 years ago
I have two questions regarding Z Wave network routing:
1/ is it possible with Zipabox to visualize the routes for all the devices?
2/ how can we update existing routes for a device when it was moved for example?
regards
Replies (6)
Yes, this is network heal under controller setting at the bottom
Thanks for yours answers.
Other questions:
- "Other routing nodes" means that the devices are directly accessed or not?
-"Non routing nodes" are battery powered devices but how can we know by which routing node they are routed?
Other routing nodes are usually battery powered devices that can route (act as repeater) comms from/to another devices to/from the controller. Non routing nodes are usually battery powered devices which cannot route comms from/to another devices to/from the controller, these can only use routing nodes to talk indirectly (if required) to the controller.
You can find 'neighbor nodes' in the settings (in the module manager) of a module, in the advanced tab, scroll to the bottom.
I can't find anymore the NETWORK HEAL option in the controller settings tab. Do you move it?
In device manager, Zwave network has a wrench setting. This is the new place for it.
Ok, thanks. It's not so simple to find it.
