Zipatile keeps losing WiFi Connection
Jeroen shared this problem 7 years ago
Hello!
My Zipatile keeps losing the WiFi connection every once in a while. I need to wake the device manually by pressing the button on top, after which it will connect again in +/-15 seconds.
This used to happen once every two weeks, but now it happens almost daily. I already have the checkboxes "Wi-Fi Default" and "Wi-Fi Required" checked, and I have no possibility to get an ethernet cable to the spot where the Zipatile is. WiFi signal is very strong and stable, available in both 2.4 and 5 Ghz, and I have tried several routers and SSIDs.
Any suggestions? At this moment the whole system is very unreliable, as chances are 50/50 that something will work (or not). I always use either the App or voice commands through an Echo Dot, so it is essential that the device is online.
Thanks,
Jeroen
Try isolation 2.4 onto a different name than your 5ghz. This might work. At least this happens on Unifi APs.
