Zipatile Leds and buttons in rules
I have an idea regarding providing feedback based on conditions, and I want the Zipatile LEDs to provide this feedback.
For example:
I want the LEDs to be white per default
I want the LEDs to be red if the alarm is armed
I want the LEDs to be green if the power outlet controlling the engine warmer is on
The reason I want the LEDs to be white per default is to be visible so I can "see" the buttons, and then press the upper right button if I want to start the engine warmer (LEDs goes green), and long-press the upper right button if I want to turn off the engine warmer (LED goes white).
Think the same for controlling the garage door, etc.
Q:
* I can set the color of the LED to pretty much any color, but not white. How do I set the Zipatile LED to white in a rule?
(it would be great if I could simply write the color code in the rule field...)
(it would be great if I could get the same "choice" as with the Zipato lightbulb, there I can choose white and how warm a color should be)
Dear All,
Thank you for taking the time to report this bug.
We will do our best to resolve this issue as soon as possible and we will keep you informed about the progress.
Please be patient.
Pero Zovkic
Dear All,
Please be patient.
Pero Zovkic
It used to work like that. Then something happened and no longed did my buttom backlight change accordingly. I had to create rule to monitor the color based on armed / disrmed which works, but for some reason every day I see the zipatile having white buttons at a stage. Not sure why.
It used to be the choice of SETRBGW on the ACTION puzzle drop down, I guess with the new firmware it changed... we should report this to zipato.
Dear All,
Please be patient.
Pero Zovkic
Dear All,
Please be patient.
Pero Zovkic
I think we can mark this as solved
