Zipatile Standby Problem
Siegmund Freudenberg shared this problem 8 years ago
Hello, i gut my zipatile a few days ago. After the first start it want to update Android and a few apps. After the update everything looked fine, but after it goes in standby the screen don't show something. You can only see a Black screen with some darker links. Android is working because i can change the loudnes.
The online thing i can Do is too restart!
Firmware Versin: 1.3.13e
Modellnummer: Zpatile-v1.1
Build-Nummer: Zipatile-V1.0.8
Replies (8)
0
You have wrong OTA version installed on your Zipatile.
Please follow this procedure to install right OTA. After last update your Zipatile version change so I cannot give you exact OTA version.
YOu will need to try with all 4 updates and one of them is correct. (NOTICE: installing wrong OTA will not harm your installation or your device).
THere are 2 ways to install this update:
1. Over SD card (not bigger then 4GB)
- copy this file to your SD card (below are OTA update link).
http://ota.zipato.com/zipatile/ota-v1.0.8-zipatile-v1.3.zip
- change the filename to: update.zip (update.zip should be alone on the SD card or in root of SD card.)
- put the SD card into the ZipaTile
- press the ON/OFF button and press Shut down
- when the ZipaTile shuts down, press Volume down button and hold it until you see the Android logo (green robot)
- that's how you will know that the upgrade started
- after update your ZT will restart
2. If you don't have SD card copy update.zip to local storage.
- when the ZipaTile shuts down, press Volume down button and hold it until you see the Android logo.
- you will access recovery mode. Go to install from sdcard -> sdcard -> find update.zip location and run it by click on it.
Thanks, works fine
mit freundlichen Güßen
Am 2018-08-13 15:45, Zipato Support Portal <mailer@3plus.hr> schrieb:
Thank you for your feedback.
On version Zipatile-v1.3 we had issue that after OTA upgrade you receive OTA version for Zipatile-v1.1.
If you have Zipatile-v1.1 and screen issues it is definitely wrong OTA version.
We fix this on newer version but on previous one you need to update again manually.
excellent work zipato support. Nice to know the cause, thanks.
Hallo.
Erst hatte ich Probleme mit dem Bildschirm. Hier wurde schnell geholfen.
Dann fehlten bei der Einrichtung die interen Sensoren. Ich habe mehrfach die Zipatille SN ZTA7E6CE28C6B697F8 zurückgesetzt. Jetzt kann ich micht nicht mehr registrien.
Hello.
First I had problems with the screen. Here was helped quickly.
Then missing in the device, the internal sensors. I have repeatedly reset the Zipatille SN ZTA7E6CE28C6B697F8. Now I can not register anymore.
Am 2018-08-13 17:13, Siegmund Freudenberg <sf.dd@web.de> schrieb:
Thanks, works fine
http://ota.zipato.com/zipatile/ota-v1.0.8-zipatile-v1.3.zip alguien tendra este archivo? tengo el mismo problema
TENGO UNA PREGUNTA, NO ME ABRE LA APP DE ZIPATO ZIPATILE SE QUEDA EN NEGRO Y YA ACTUALICE DESDE sd LA VERSION DE ZIPATO
Is it possible for someone to post the firmware 1.1 or 1.2 or 1.4 here in the forum?
I have problems with 1.3 Display stays black. Unfortunately, the Zipato service can't help me because Zipatile 1 is no longer available.
