Zipatile Widget
Christoph Krieger shared this idea 10 years ago
The widgets are loosing Settings after a minute of adding. Immediately after adding it works. One minute later I can press on it and nothing happens. When I try to edit all Ticks are gone. When I set the Tick again it works for one minute and then it is the same again.
I have only tried it with the Switch Widget. When I place it on the home screen I select the device and then it works. That means I press the Widget and the on/off Button enlarges. But one minute later nothing happens when I push the Widget. When I longpress the Widget and go to edit the Mark is not set anymore. When I set it again it works again. But one minute later the same issue.
