KNX interface to ip
im considering the Zipato Zipabox Duo. Planning to hook it up to my existing KNX installation and expand with Z-wave products.
Just one question:
- I've got an KNX IP Gateway which has an local IP on my LAN (picture of the module - http://i.imgur.com/5a2O7nK.jpg ). Can I access the KNX resources with the Zipabox Duo over IP or do I need the KNX module which hooks up to the KNX bus?
ØyvindT
Norway
KNX over IP was implemented some time ago.
That is a very good question. The only one I know uses KNX devices succesfully is a guy named DerHelle, he's got a blog http://zipabox.de/, either you can ask him and/or you can open a ticket in zipato support.
Thanks Alberto, I'll ask DerHelle. Have you got his email adress? (Couldn't find one on the blog site).
I don´t think this will work. I seems you have to buy the KNX Expansion module. Otherwise i have many problems with the module. No 2 bytes datas get recognized (for example temperatur....)
KNX over IP is not possible. You only can do it over the connector.
regards Helle
regards Helle
Thanks Alberto, Marcel and derHelle. I think I'll just try the KNX bus approach and do some testing within the stores free-return period.
Hey,
I saw that KNXIP is now available.
regards Helle
Hey,
regards Helle
I have it with KNX IP tunneling and it works fine.
Nice, will try with my KNX Lab setup. I was thinking of doing KNX-Zwave gateway for expanding KNX to Z-wave.
And what is better? KNX Tunelling or dedicated Zipato module?
Please share :-)
Please share :-)
Separate, because if you choose multimeter, it take only first device :-D you must play with it.
Hello Pavel,
Pfff.. no way, i spent 10 hours and no result...
Dont know what to do ....
Hello Pavel,
Do you have correctly set KNX? You need to export project from ETS software and have KNX S-mode points. After that you will get esf file, and then you can use it in zipato. If you have temperature for example, you will choose meter in knx ip, choose correct item from esf file to value1 and synchronize. Then you have to wait, when the temperature sensor change temperature and send value through KNX network. It can take some time.
It's working!
In fact i was supposing that Zipato was polling the device... but it just read it from network.
So, when I was reading the datapoint from ETS, it was sending, Zipato was able to read it.
I've change the setup on the device to broadcast the value on the network, and it works now ! (of course, only Meter, not MultiValue or Value..)
Thank you!
It's working!
Thank you!
