Adding Doorbird
M Wolf shared this question 8 years ago
Just a quick question. I want to integrate the Tile with a Doorbird D2101BV, but the latter is not on the list. Hints? Thank you
No, just have to wait and see if Zipato will integrate them. You could try just using a D20x series?
Doorbird haven't even release the new API for these models yet, so you may have to wait
This this I got just now from DoorBird
"The integration should also work with our new one button devices. The API for the multi tenent devices will be available soon. As soon this information is available, it is very likely that Zipato will add the new functions. Please keep in mind that we are not responsible for this integration and do not have information available when something can happen.
It is very likely that our specialists will get in touch as soon as the new API 2.0 is available."
The D2101BV is not on the list when adding new device to zipatile. Really confusing.
And this
"The current API does deliver every function for the D2101V that was available for the D202. It should only take a few adjustments for it to work. As we do just provide the API and did not participate in the integration, Zipato needs to do adjustments. It is likely that they wait for the API 2.0 before they become active, but this is just a guess as we do not have information available regarding their roadmap."
in this case adding a d2101 as a D201 should work. you just wont have access to the extra relay on the d2101.
Checked. Doesn't see see the DoorBird
