Synchronization button for the module offline or with problem
DER5LU shared this idea 13 years ago
It will be good to have a button on the dashboard for each module (Or one function that we can select the module) to do re-synchronization if we have problem on a module when it is offline or with a problem.
In the case, it not necessary to resetting and remove the module from the Zipabox. We don't lose all setting and rule where the module is mentioned.
In the same philosophy, an button on the dashboard to test all modules synchronization (Or only one) will be good.
Have a nice day.
