pb with version 1.3.13
Hello
I've just updated my Zipabox to 1.3.13
And now it's alway offline
I've already reboot, but the problem still exists
I have the same problem with several zipatile are offline with this new update
Version 1.3.13 is also causing problems on the Zipamicro. Mine is connected via ethernet and it stays as offline. I've tried manually restarting it and no luck so far.
After update a device of mine went out of network. Problems over problems...
Like always, no changelog ...
After two weeks, I still can not add Wallmote quad.
So what's new ????
So what's new ????
The only answer I have from Zipato is : "Check your home router/firewall"
ha ha ha, the only think I did is to update this shitting Zipabox !!!
i am constantly getting messages since 1.3.10 that my controller is unreachable, then 10-15 minutes later, reachable again. This happens about half dozen times a day. And I still cant login locally either.
Thankfully my network is fine, and my internet connection, so I use Imperihome app or Alexa and it works fine.
If only Zipato released the local api and local login WITHOUT internet connection worked, I would have had other developers add this support to their apps, such as The Home Remote.
I had similar problems with zipabox after 1.3.10 firmware upgrade
Zipato Tech support asked me to do a hard reset of the zipabox :
https://community.zipato.com/knowledge-base/article/zipabox-hard-reset-procedure
then after hard reset the box was on line again but with an old 1.0.32 firmwareso I upgraded to 1.3.10 and everything was fine and on line
I did not loose any rule or device in this process
and I will be staying at this firmware reading your feed back about 1.3.13 !
