1. Unplug power and Ethernet cable from your Zipabox
2. Wait 1 minute
3. First plug in Ethernet cable and then power supply
4. Press and hold Button 2 on your Zipabox and then briefly press and release Reset button
5. Keep holding Button 2 for 5 seconds and then release it
6. Observe your LED sequence, if everything goes right at the end there should be fixed green LED light
Notice: Hard reset procedure will recover the Zipabox system with older Firmware version, except Firmware everything stays on the Zipabox as it was before (devices, user accounts, personal data...). Firmware upgrade is advised to do afterwards so that you can use all new options and features introduced by Zipato.
