1. Check your Internet connection
2. Check whether you connected your network cable correctly to your Internet router
3. Press "reset" button on the Zipabox and see if after reboot you will get steady green LED light indication
Zipabox - Waiting for more than a 5 minutes and still there is no steady green LED light indication
Is this article helpful?
