How to upgrade or downgrade the firmware version on Zipato controller
This application note shows how to upgrade or downgrade firmware version on Zipato Controller over the Control Center.
Project aim
How to change the firmware version on Zipato Controller over Control Center.
Zipato Controller configuration
Components
-Zipato Controller
Process
First step
Before you start process of changing firmware version. It is necessary to check current version of firmware.
To do that You will need to click on Zipato logo in top left corner and bellow of controller name, there is a current firmware version.
If it states that your firmware is „up to date“ than it is not necessary to follow further step. Unless our technical support is not requested you to do that.
Open Controller settings inside Control Center. Then find Firmware frame in which you will have list of all available firmware versions.
Upgrade
You will need to choose Beta (Newest) from the drop down menu and press LOAD.
Downgrade
You will need to choose Official from the drop down menu and press LOAD.
Last step:
After you press Load there will be popup window in which your will need to type „YES“ and after that process of changing firmware will start.
*Important: This process can take few minutes. It depends on your Internet connection capacity. Please do not unplug power supply cable from the Zipato controller in this process.
Is this article helpful?
1 0 2
