This application note shows how to remove Wall holder from the ZipaTile
Project Aim
The aim of this project is to show three ways in which you can remove Wall holder .
Components
-ZipaTile
Setup and Control
To remove the Wall holder, slide the cover towards the bottom of device until the cover no longer slides.
Then with the front of the ZipaTile facing down, pull up the Wall holder.
